It is currently Fri Jul 25, 2025 12:00 am
PostPosted: Thu Jul 10, 2014 4:54 pm
Last Name: Winkel
City: Los Alamos
State: NM
Zip/Postal Code: 87544
My wife and are are close to running the first files on our CNC. What basic router bits should we be using?
PostPosted: Sat Jul 12, 2014 11:31 am
First name: Jamie
Last Name: Unden
City: Lakeside
Zip/Postal Code: 92040
It depends on what you are cutting. My biggest usage is making MDF router templates so I use a 1/8" bit for cutting them. I use a 1/2" or 3/4" for leveling the scratch board. I use a 1/4" ball-end when doing fretboard contouring. I always get solid carbide. MDF dulls even those pretty quickly.
PostPosted: Mon Jul 28, 2014 2:34 pm
First name: Peter
Last Name: Fedorick
City: Calgary
State: AB - Alberta
Zip/Postal Code: T2Z2E9
It really depends on your machine and the job at hand.
My machine is limited to 10,000 rpm and has a hard time getting above 200 FPM.
I get best surface finish across the grain at around 100FPM
Pay attention to speeds and feeds.
Most hardwood has a surface feet per minute SFM of around 2000.
Chip loads vary with bit size but those provided for aluminum seem to work well.
There are lots of speed and feed calculators available just do a search.
CNC cookbook is a good source.
I go all carbide as HSS will dull quickly if the cutting speed is off.
I like uncoated 2 flute carbide spiral end mills rather than straight edge router bits.
My general purpose bit is an up cutting 1/2" bit and I use down cutting bits for pockets.
I use a 1" straight edge ball router bit for shaping and 1/8" down cutting and smaller for inlay and tight radii.
PostPosted: Fri Aug 15, 2014 4:31 pm
Last Name: Garrish
Peter gives solid advice.
Bob Garrish
